- Joined
- 27 Nov 2013
- Messages
- 1
- Reaction score
- 0
- Country
I have a problem with the hot water / heater model VAILLANT VCW B 24-10.
I can control the temperature of the central heating water with a control knob, setting 1-9.
If i set the ch temperature to 5 or higher the heater doesnt produce hot water anymore, the ch keeps working fine. There is no ignition of the burner when i try the hot water.
If i let the heater cool of a bit and set the ch temperature to 4 there is no problem. The hot water works fine.
I already replaced the sensor of the temperature limiter but the problem still persists. Any ideas ?
Thank you,
Thank you,
