Hello,
I have a Chaffoteaux et Maury Sterling PP combi boiler. The central heating is working as it should but the hot water temperature is not as hot as it should be. When the hot tap is turned on, after a few seconds, hot water starts to come through but then the temperature drops to luke warm, then goes back up again and so this cycle continues.
On checking the boiler when the hot tap is turned on, the burners stay at full height for around 60 seconds and then they drop down for about 6 seconds, then they go back up to full height again for around 60 seconds, then drop down again for 6 seconds. This is continual whilst the hot tap is on and the periods of time between the burners being at full height and at low height is always around 60 seconds and 6 seconds respectively. As a consequence of this when filling a bath, the water is only luke warm.
I have put some sludge remover in the c/h system and am running the central heating when I am not in and will drop this and give the system a flush out at the weekend but I am not sure whether this will actually do any good?
Does anyone have any suggestions as to what the likely cause of the fault is.
Cheers
Mr M
Cheers
Mr M
