According to the manual, the burner should come on under hot water demand. Mine doesn't unless the shower temperature control is cranked up to maximum which then is too hot to use. Any suggestions what might be wrong would be appreciated. At the moment I get a short warm shower until the heatslave tank is empty then the shower goes cold, sometimes for minutes. Eventually the burner comes on and the water runs hot again - presumably because the refilled heatslave tank demands it?
I'm on a private water supply at around 1.2 bar if that is significant?
Thanks for any help
Angus
Thanks for any help
Angus
