I would very much appreciate any advice regarding a problem with my Ravenheat 85CSI combi. The boiler will not heat water unless the central heating room stat is requesting heat even when the boiler is switched to hot water only. Any suggestions
The microswitch is working ok and boiler fires water starts to heat then boiler cuts out it goes on doing this unless the room stat is turned up? even when switched to hot water only.
Burner keeps cutting out then firing up again and as it starts getting hot it cuts out again. The puzzling thing is why doesn't it do it when the central heating is on the hot water works fine.[/quote]
