Hot Water Problem
26 Jan 2009
Somerset
Can anyone help me solve a problem i have with my CH boiler.
It is a Ravenheat LS100T. The hot water seems to be heating up via the central heating when on demand, the heating used to turn off and pump stopped when turning on the hot water tap, now it doesn't and it takes a while to warm the water, if the boiler goes off for the heating it starts to run cold :confused:
I still have hot water when the central heating is on but when it's in off mode the the boiler doesn't fire up when the hot tap is turned on, i checked this by turning to summer mode. does it have anything to do with the three way valve or the diaphram within it, could it be stuck and would this give me these symptoms :?:
I would check the diaphragm first as this is what will tell the boiler to fire for HW.
If rads are getting warm when HW is on, then sounds like DV is stuck.
