Hi all...
Ive just moved to new property and have found the hot water system a nightmare.
The boiler is a 'pulsa coil 3' supplying no rads just bathroom and kitchen.
The problem is when I turn a hot water tap on its ok for a few seconds then the flow just fades away to nothing....turn it more....It's ok......then nothing again... until you turn the tap fully open.
The shower is worse.....scalding hot for ten seconds then cold, continuously. The spur for the pump is always kept switched on. Any ideas as to the possible cause...?????
Thanks.
Thanks.
