hot water problem
11 Oct 2009
Belfast
hi everyone some water got into my ferroli optimax 25 c and blew the 2 amp fuse inside i dried it of and replaced the fuse turned it on and it fired up c heating working fine but hot water not working. opened the diverter to check the wee motor its workin fine. should this motor stop when hot water is on to let the valve open :confused:could it be a faulty cvbc
What exactly got wet? electricity and water don't get on very well together, so what got wet is probably deceased, dead, no more, an Ex-Component!! :LOL:
there was water i the main curcuit board it blew the fuse insidei changed it.its a ferroli omptimax 25 c if theres a fault it should flash a fault id code but doesnt.the ch workin and i can turn the divertin valve by hand and then hot water works could it be the motorized valve :rolleyes:
everything else working clock,programmer.it even fires up when the hot tap is turned on .the head of diverter turns brings the arm over to b position when powered up.should the arm go to A POSITION when hot water is operating :?:
