I hope someone can help.
i have a combi boiler vaillant turbomax, when I turn on the hot tap it just doesn't get hot, it gets warm but never boiling,when I run a bath I have to use just the hot tap because if I turn the cold tap it goes freezing. The only way I can get boiling water is to turn the cold tap on the basin when I'm running the hot tap on the bath.
It's also the same on the mixer shower, I first called the shower manufacturer who said t sounds like a boiler problem rather than the thermostat in the shower as the water comes out hot when restricted flow or cold water from another source is running.
i hope that all makes sense and someone can shed some light on my issues
