- Joined
- 29 Oct 2024
- Messages
- 1
- Reaction score
- 0
- Country
I have a new indirect hot water cylinder to fit to replace a leaking cylinder. Our hot water pressure at the taps has always been horrendous and it's always been in my mind to fit a pump. Since I have the cylinder out I thought now might be as good a time as any to add a pump as well.
We have four sinks and a bath that are fed with hot water. Showers are electric so no requirements for them to have hot feeds. Cold water to all the sinks are mains fed so are already at pressure, so I will only need a single impeller pump.
My question is will I need a flange on the tank for the pump feed or can I use the secondary output that is on the side of the new tank (effectively an essex flange?) to feed the pump and then connect the top output from the tank solely to the vent pipe back into the cold storage tank?
Also any recommendation on particular pump brand? Originally I was thinking about a salamander but I've had a change of heart based on some of the reviews I've seen regarding reliability and lack of spares. Grundfos is a brand I've seen alot and I'm leaning towards one of their pumps now instead.
TIA
TIA
