- Joined
- 17 Oct 2005
- Messages
- 158
- Reaction score
- 2
- Country
Hello I just want to ask the question on average how long are we talking in months or years for radiators and central heating pump to get damaged by oxidation when oxygen enters the central heating through the C/H cold water header tank in the loft? - at the moment if the copper immersion cylinder is satisfied with heat (60c) and the zone valve turns off and when the radiator zone valve is satisfied that shuts off - if both valves are shut off i can hear the water trickling into the cold tank in the loft, if at least one valve is open then i cannot hear it pumping back into the header tank, so it only pumps back into the cold water tank through the expansion pipe when both zone valves are shut and pump still going (oil boiler off at this stage because it has reached temperature) - i know its not ideal this way and oxygen will be getting into the system and I've heard plumbers say this will eventually damage/rust the pump propeller and the inside of the radiators if this is happening, but im just wondering how long roughly that damage will take? Thanks.
