The builder is claiming for the fitting of the above as an additional item. The contract specified a 3 speed bronze circulating pump, on secondary return to a buffer vessel. Is it not likely that these are one and the same thing?
DAB do make a bronze circulating pump.
But why are you using a builder?
Should be a heating engineer!
Tony
How do you know the builder isn't employing the services of a plumbing/heating engineer???...I've worked for many a builder...DAB do make a bronze circulating pump.
Tony
He just gets worse Dan...not a fookin clue..it gets embarrassing knowing this clown is in the same profession as us..DAB do make a bronze circulating pump.
Tony
WTF?
The actual product originally specified (and which I assume this replaces - but I might be wrong) was a Grundfoss Alpha 2 UPS 15-50N. Not being on site, I don't presently have a model number for the DAB pump.
