Property is 4 years old and has a mains pressured hot water system. I cannot find the hot water shut off valve anywhere - Loft, airing cupboard, sink.....
Anyone have any ideas? I'm obviously blinded by the obvious!!
if your sytem has a combi boiler then you will not find a hot water shut off valve, the hot water is heated direcly via the boiler. you will need to turn the cold water off to your boiler.
You can check by turning on your hot water tap and see if your boiler comes on with in a few seconds
