Hot water supply problem.
15 Jan 2006
Bristol
Hi Everyone,
I have a Worcester 9.24 Electronic RSF boiler, when I run the hot water quite often the central heating heats up at the same time and the hot water doesn't reach full temperature, this is with the central heating switched off. I've observed the diverting valve which operates correctly, I've also pressed the micro switches which seem to work ok, 1 turns the boiler on and the other operates something but only with the first depressed. I guess the problem is with whatever the micro switch controls, but I cant find out what this is?
When the boiler works properly the central heating remains cold until I turn off the hot tap when the boiler seems to release a small amount of hot water into the central heating, I guess when this valve re-opens to the central heating system.
Any help on rectifying this fault would be appreciated!
