- Joined
- 31 Aug 2021
- Messages
- 14
- Reaction score
- 0
- Country
Another heating mystery in my house. Currently neither towel rail gets hot even when the rest of the radiators are warm. The likely diagnosis by a heating engineer yesterday are the pipes are blocked, (they are 8mm microbore after all - and once he measured the pressure in them after disconnecting a towel rail, there was frankly a pathetic amount of water dribbling out) and should be repiped with standard pipe back to the main feed manifold and then everything to be rebalanced. This is fine with me - anything that reduces the percentage of microbore in the house can only be a good thing and since I'm having a bathroom refitted, the floor is already just boards and taking it up isn't going to be a hassle. I'm jus waiting on a price and a date.
However... It re-raised the question in my mind of why (back when they used to work) the towel rails would get hot in summer, even if the heating was turned off. At least that's how I remember it. Two of my neighbours - both plumbers (one a heating engineer) themselves, say all the houses on this street (McAlpine, built in late 1980s) have the towel rails connected to the hot water system so you can have warm towels all year around. And that explanation does fit with them being hot in the summer. The heating engineer yesterday says they do not work off the hot water system - the opposite opinion.
But how does that even work? Surly if that were so you'd get brown water out the hot tap. The bathroom fitter said he'd never heard of such an thing.
Is this idea actually even possible ? Is it likely and if so, how does that actually work in reality?
