Hopefully someone can help me out with the problem im having with my hot water (or lack of)
Background info: The boiler is a Range Flowmax 180 electric boiler, manufactured in 2004 and as far as i know was first used when the flat was built in 2004.
The flat has one downstairs bathroom with sink/shower
Upstairs shower room and sink basin
One kitchen
The problemThe boiler/hot water system in my flat has never seemed to work properly.
The problem is maintaining a constant flow of hot water. What commonly happens is that the hot water tap in any of the above rooms get turned on. Initially Very hot water generally comes after a few seconds however after around 30 seconds to a minute the flow of water quickly changes from hot to luke warm and eventually it flows only stone cold water.
If you leave the tap running it the flow seems to randomly change from hot, warm and cold but more often than not its mostly cold. Theres no chance of leaving a running bath to fill up as 9 times out of 10 you’ll come back a few minutes later to find a cold bath. This used to be an occasional to regular problem but it’s now happening all the time. Ive been reduced to taking very fast showers before the water runs cold.
Ive had a look in the water tank and the water heater seems to be working. I can hear the boiler working when it’s set to come on and it is possible to lift the plastic cover from the top of the boiler and check the water level and temp inside. Ive checked the water temp inside several times and the water is well hot (enough to burn your hand) So the tank itself is producing and holdong hot water, it’s just not coming out from the tap!
Does anyone have any suggestions as to what it could be or anything i can do/check before having to get the wallet out and professionals in to look at it.
One kitchen
