£450 - depends how you work it. £150 retail for the cylinder, plus fittings, heating inhibitor, immersion heater.
Then 8 hours at £30/hour - that way it looks about right.
Depends if your man has boilers he can be fitting instead.
36x 16 10 metre head I did last month including new timber base £375.00 all in, no inhibitor though as new boiler being fitted soon so add on approx £15 to £20
If cylinder has already been changed 8 years ago pipework alterations during install should be minimal. Price will depend on wether guy wants to spend all day farting around or get job done quickly and efficently. Materials will be between £150 and £175 .
The old cylinder is leaking around connectors. Plumber wants to change whole thing. This means he thinks that the old cylinder is bu**ered... overtightening the immersion heater into the cylinder can damage the cylinder, causing leaks. This would suggest that perhaps the guy who did it before wasn't a pro plumber (or was a very bad one!). Hence the low cost.
