hey Guys,
first all im new here so hey 2 all!!
im here cause iv got an issue with my hot water tank. its got a slow leak where the heating pipe joins to the tank. the fitting that joins the the pipe and the tank, screws into the tank and it looks like a compression fitting at the pipe side. anyway, there us a slow leak at the tank side of the fitting.
now im having an issue opening the fitting and even if i could im not sure replacing the fitting will help. is there simple solution to this issue such a sealant or something that would be suitable to resolve this issue??
my mate told me that lsx jointing compound would do the trick but from what i know of it u really use that inside the fitting to seal the joint???
Any advise would be appreciated, thanks!!
