Here's another puzzler for you: As part of my ongoing saga of heating coming on in the night when the controller's clock is "off", one of the BG engineers replaced the valve and actuator on the hot water tank. He described the original actuator as "motor on/motor off", but the new one is "motor on/spring off" like the heating zone valves. There's no maker's name that I can see, but it's labelled "BGMVSP-2".
After he left, I didn't have much hot water
Over the past few days I've determined that (a) the tank thermostat seems to open and close the valve correctly, but when it opens it doesn't trigger the pump to start, so I only get hot water if the pump and boiler are on because of heating demand, and (b) if the valve is closed and I open it by hand by pushing the lever on the actuator, the pump and boiler do start -- even if the programmer clock is "off" -- though, of course, the valve reverts back to its closed position as soon as I let go, and the pump then switches off
I'll be getting the engineer back next week, but in the meantime does anyone have any ideas how this could be happening please? I hate to see people just replacing parts, without knowing what's really going on.
