Background: I've owned this place for 18 months - as far as I can tell it was refurbed in the 90's by well meaning amateurs and then neglected for the last 10 years by the subsequent owners. I'm doing a combination of major upgrades and fixing what isn't working to last long enough until it gets replaced as part of the appropriate major upgrade. The heating system is getting done next year.
With that out of the way, I don't believe the hot water thermostat is entirely reliable. It seems extremely variable if it will turn off, and the control box appears to give priority to hot water over central heating, so if I don't keep it set low enough, there house gets cold. This leaves me with not quite enough hot water for a full bath.
One option is just to replace it - its £20 and a minor wiring job so no issue there.
However I can't find any documentation on how close the metal plate on the back of the thermostat should be to the tank? Its spring loaded to push it back, but the plastic sides of the thermostat keep the plate a good 2mm away from the exposed wall of the tank where the insulation has been cut away.
Is that normal? Or is it incorrectly fitted? My instinct is to say it should be up against the copper in order to have an accurate reading.
If it is wrong, is there a standard way of fixing this?
