We have had a WORCESTER 24i greenstar boiler installed for ten months, and its running perfectly, At the time the boiler was installed we had the CH/HW system changed to a fully pumped system, and a Cylinder stat put onto the HW cylinder. However, our hot water is really HOT, too hot.....I have slightly adjusted the cylinder stat downwards, but that has made no difference, so i have a couple of questions for you. Is the control knob on the front of the boiler a TEMPRETURE contol. ie adjusting this will alter the temp of radiators and HW. And Whats the best way of testing the Cylinder stat is working.....and If i turn the sylinder stat right down will it turn the boiler off or just stop the pump.
