i have a worcester 24cdi combi boiler which has worked fine for the two years i've lived in the house. recently though the hot water has been getting less and less powerful. the hot water temperature is fine but when a cold tap is turned on the hot water goes off. looking at the boiler when this happens i saw the arm from the heat exchanger which operates the microswitch retracts when a cold tap is on so the boiler thinks there is no longer a hot water demand and switches off
i got a boiler man to come take a look and he replaced the diaphragm but this hasn't fixed the problem. a friend suggested a pump for the hot water supply but at £250 it seems a bit risky incase it doesn't fix the problem. can anyone suggest anything else which could be causing this?
