hot water underfloor heating
13 Aug 2008
Essex
During renovation underfloor heating was fitted into the kitchen and works fine via its own room stat. I also had it looped into the area where the conservatory was going from and separate manifold. This is now built and I want to extend the pipe/s and fire it up. I'm fairly sure there is no water in the conservatory loops. Both manifolds get hot as the water flows through them, but it appears that the manufactuers blanking caps are still fitted to this manifold where valves or controls to each pipe should be.
Do I need to get these valves/ contol knobs. or
Could I use the ones from the other manifold just to open the flow
I think like most other people I dont really understand what you are asking.
Obviously each end of the UFH loop has to be connected to the flow and return manifold.
Since the flows need to be balanced between the loops then its would be usual to call an experienced person to do that.
Tony
