i have a RANGE TRIBUNNE HE cylinder and i have turned the cylinder thermostat right down but the hot water coming out of the taps is too hot to put hands under.but before i change the stat was just wanting to see if anyone thinks there could be another fault and not the stat.there is power going to it and it does click when i turn it and the valve at the side opens and closes when i turn it and make it click,and most of the time it is showing the valve in the closed position.the stat is a RANGE TS95H30 with 2 probes going into the cylinder,cant find no info regarding that stat anywhere.any help appreciated.
