I have an old pilot light boiler with stored hot water. The system uses an indirect fortic type vented cylinder to store and heat hot water.
Recently the boiler stopped working altogether. When the system was switched on it the boiler would overheat due to lack of circulation and then cut out. The thermocouple would cut off the pilot light.
I partially drained the system and added the central heating flushing compound with the intention of running it in there for a week and then flush and refill again.
Things got in the way, and then in the last couple of days the boiler again cut out. The front of the boiler was very warm, which lead me to the conclusion that it had cut out due to lack of circulation. The flushing compound had been in there for over a month
I drained the system and fitted drain cocks near all the radiators downstairs (3 in total) to make draining down easier in the future.(The only way of draining it before then was to remove a pipe from a radiator valve).
Anyway, yesterday I refilled the system in the usual way. I turned on the water into the header tank and bled the rads working from the lowest one downstairs and up to the rads upstairs.
Then I tried running the system again. I noticed the pump was noisy and there was a lot of air in the system. The problem is the boiler is on the top floor and is higher than any of the rads.
I left it running last night for a bit in the hope that the air would work its way out.
At the moment I am getting hot water, but no heating. In fact the heating only option causes the boiler to cut out due to overheating as it has done before.
Also, I understand it is possible to bleed the pump. It's a standard grundfoss pump. Is this via the large screw in the middle.
