Hot Water
22 May 2009
Cheshire
My Bathroom basin hot water tap is not working properly. The problem is when i turn it little hot water comes out and then stops.The cold tap works fine . Can anyone help me please?
so your saying nothing comes out when its on full but other tasps are ok.
My Bathroom basin hot water tap is working properly. The problem is when i turn it little hot water comes out and then stops.The cold tap works fine . Can anyone help me please?
so your bathroom basin hot water tap is NOT working properly
maybe a faulty tap washer or the pipe has a blockage.
what supplies your hot water ? a combi or from a hot water cylinder.
Is it connected with a braided hose is it kinked or is it flat, does it have a service valve? is it turned off? We need more info
Its a combi boiler. If its the faulty tap washer is it easy to replace? and if its a block pipe how do i unblock please.
