My washing machine has started to stop before the spin... or perhaps rinse. In actual fact I have noticed that at times it stops at other various points of a cycle depending which program I use, but mainly before the spin. The door lock also flashes. The door lock sometimes also flashes before the wash starts, hence unable to progress.
I found the way around all these problems is switch off the machine from the wall and re switch after 10-15 seconds. It sort of resets itself, then re-programme the machine wherever it left and all is done. This is not happening all the time... but probably half the time the machine is used.
My instincts are telling me it is a motherboard problem, but could it be something else causing the issues that I need to look at before I dish over £100 for a new one?
Your advice much appreciated.
