Hi all, I have an issue and need some advice.
My hotpoint wd440 washer/drier will not pump out the water. i have read some posts here and have removed and cleaned the filter but the fault still occurs. The fault lights no 2 and 4 are flashing along with the power light. the wash cycle works ok but stops when it should pump out. if i lower the drain pipe below the level of the drum the water now drains ok so i am confident the filter and pipe are clear. Any advise on what is wrong would be great also a cheap parts supplier and fitting advice would be much appreciated.
Many thanks.
Many thanks.
