to motor 1 to pump only short hoeses thoetip the mc back ,underneath at the front is a long black pipe from the sump, remove it and clean inside of pipe under a tap its blocked with crud that will stop it filling with water .
took the 3 hoess off felt in side all clear turned the machine on while tilted pump ect seem to be workin but no water is being pumped throughyep thats the one from base of sump about inch half wide .2 clips on each end about 8 inches long
have you checked the inlet hose for kinks and disconnected it from the mc to see if water comes out of the pipe .if thats ok and no crud in the pipes .then the circulation pump is faulty cost about 80 quid its not worth it on a ten year old mc .
thanks for you help got told it
s the soliniod ? £29 I will see if the water comes through thanks agian for your help
