Hi - I have a fault where the control knob clicks round as if the machine is working but faster than normal and the drum does not turn. Water pumps in and out ok but in the pump out stage does not stop pumping unless I move it on. I also managed to get it to spin once by starting at the rinse stage. Belt is ok as you can feel it when turning the drum by hand. Looks like it might be the control knob/switch or maybe a cct board inside. Can anyone suggest what this might be?
Mark
Mark
