HOTPOINT AQUARIUS 1100
8 Sep 2005
worlds end
WASHER RUNS THROUGH ITS CYCLE BUT DRUM WILL NOT ROTATE ,BELT OK,MOTOR/DRUM NOT SIEZED, NO VOLTAGE TO MOTOR ,ANY KNOWN COMMON FAULTS OR CHECKS I CAN DO.THANKS
__________________________
please see forum rule 6
The feed to the motor is via the programmer on the programmer pcb at the top looking down onto the pcb there is if I remember correctly a fixed ceramic fuse measure this for open circuit if it is open chances are a short on the motor has taken the fuse
