Hi there, the empty water light on my CTD00 came on and so I emptied the water but the light now remains on. The drum will turn but the heating will not start (I believe because it still thinks the water is full). Any ideas on how I can reset it?
Thanks for that. Opened up the cover at the bottom and it was full of water. Inside the pump the rubber 'blades' had come off so I've stuck it back on! Hopefully my botched job will last!
Hi
I have same problem.
Mine is a hotpoint condenser dryer CTD00G.
Ive taken the tray out at the back and had a look. The tray is filled with water, its not pumping and actually I dont think there is any power going to the pump. Theres no noise from it and its not moving at all. I even tried it with the pump out of the tray to see it i could at least see it struggling to move but not one movement.
Will the whole pump need replacing? Im a novice to all this so was wondering how hard it would be as i see some wires going into the pump
