Hotpoint Aquarius DF61
12 Dec 2011
Lanarkshire
The other day my kitchen sink got blocked whilst the dishwasher was running. I then noticed the water coming out the bottom of the washer. I have now got the sink unblocked but I cannot get the washer to go. When I start the cycle you can hear the humming noise but the dial wont turn and it just keeps humming away without taking in any water!!! ihave checked the pipe into the washer and it is fine. Any help would be appreciated.
Lewis
Water in the base , tip it forward or back and put towels on the floor. It's tripped the anti flood in the base. Then it should work
I will go and try it right now, do I need to take anything off or just tip it forward???
Lewis
Hi Rocks you are an absolute star, dishwasher is going like a train.
Can't thank you enough
Cheers
Lewis
Morning Rocks,
I have one more quick question if you don't mind. Machine worked great last night but I noticed, when the cycle is usually finished you have the 2 red lights on at the front. I noticed that the one on the left with Salt Refill underneath it was not lit up!!! Anything I should be doing or filling??
Cheers
Lewis
It's only saying to you that there is no salt in it , but if you use all in 1 you don't need salt or rinse aid.
