Hotpoint Aquarius Extra Washer Dryer Model WD64
23 Sep 2006
Birmingham
Can any one please help. On my washer/dryer when I use any washing cycle, the machine starts to fill and within about 20 seconds a small amount of clean water comes out of the bottom of the powder/softner draw. The amount of water is very slight however it is not doing my woodden flooring much good. I do not use the draw to put soap in as I use sachets. I have taken the draw out washed and cleaned it, but the problem still persists. The washer is about 2years old.
Many thanks .
Graham Turner
___________________________
lynda, moderator
your title has been edited, see forum rule 5
Try partially closing the cold valve, raise the front of the machine a little and see if it stops.
Sleepyhead
Thank you for responding so quickly. I will try what you have suggested and let you know outcome.
Many thanks.
Graham Turner
graham turner said:
Sleepyhead
Many thanks.
Graham Turner
Sleepyhead.
I tried your suggestion and it did the trick.
Many thanks again
Graham Turner
