Hotpoint Aquarius F541
6 Jun 2010
Birmingham
I have got lights 2 and 4 flashing along with on/off. The wash cycle will stop half way with these lights, if and its about 1 in 10 times the cycle finishes it takes about 6 hours !!! Have managed to finish a cycle thats errored by draining then final spinning, but draining now gives the above error, and final spin is just an endless cycle, it starts spinning but as the clothes are still soaked it stops and tries to drain again, then it will attempt another spin etc etc etc.
Any help Rocks please
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
So in this instance with the second light flashing the error code would be f04 light 2. pressure sw stuck on empty
Back to top
clean filter /pump and sink spigot your error code is fo5,you still have a blokage somewhere.
