Hotpoint aquarius tvm 570 will not stop when timer reaches zero
11 Apr 2017
Ireland
I have a aquarius tvm 570 that started to buzz when trying to start. Changed capacitor but made no difference. Took connections off door interlock and joined pink/white to grey wire and tripped mcb.re-connected wires to door switch and Reset mcb, pressed start button and dryer started turning but will not stop when timer reaches zero. While dryer is running in heating mode if I pull off red wire from timer dryer keeps running for a minute or so and then stops. I think this is thermostat keeping it going till it cools down. If it is cooling mode I.e. When it reaches the fan symbol on timer, if I pull red wire off it stops immediately. The terminals with pink/white wire and red wire seem to be permanently closed so I think timer is problem. Any help greatly appreciated
