Hi all,thanks for looking, problem with above washer/dryer
the washer at the moment turns the drum then makes a "clicking sound " after about 30 seconds
then drum stops turning and heater light and on/off light flash.
Things I have checked already.................
cleaned filter at bottom of drum ( £1 coin and other stuff )
checked pump was working ( it was )
removed motor and checked brushes ( about 15 long )
tried running machine without the belt ( same again,runs for about 30 seconds, then lights flash )
I noticed that when it " clicks " the motor for the dryer starts up.
The wife said this morning it seemed to fill up at lot more than normal then went into flashing mode.
I would be gratefull for any advice
Jim
Jim
