Hello all, first post so please be gentle
My washer/dryer decided to pack up this afternoon. The fault code I'm getting is Drying High Heat, Reduce Creases and Time Saver blinking (that is LED 1, 2, and 4 as you look at them from top down on the left hand side) and the On/Off LED blinking rapidly.
I've already found a post here: //www.diynot.com/forums/viewtopic.php?t=261493
Please can someone confirm that this is an F13 error, and how they are able to translate the LEDs to the correct error code?
I'd found this: http://www.hotpointservice.co.uk/help-and-advice/error-codes/ but wasn't able to figure out the error code.
EDIT: Image added
View media item 76979
EDIT: Image added
