- Joined
- 24 Jan 2004
- Messages
- 121
- Reaction score
- 0
- Country
I have a Hotpoint Aquarius WD62 that has been absolutely brilliant until last week when the local water board did some maintenance on the water supply which put airlocks into our system (not sure this is related may just be coincidence).
Since around that time, when used the washer does not seem to be taking in enough water, a lot of the time it is barely visible. Clothes taken out that would normally be wringing wet are barely damp and even dry in places. No settings have been changed on the washer.
I will be disconnecting the washer from the supply to check flow, but wondered if this is a recognisable problem and if there is anything else i can investigate?
Cheers.
Cheers.
