Hotpoint Aquarius WF320 Flashing Lights (1200 Spin)
25 Feb 2010
Derbyshire
hi all.
new on here and as with most ive come with a problem.
i have a Hotpoint Aquarius WF320 (1200 Spin)
i bought it from a guy that had been keeping it in a damp outbuilding, got it home and plugged it in
i started it it got halfway through a rinse cycle when it made a loud pop/bang then stopped and the power light and the top 2 lights next to the soap tray started flashing.
opened the washer up to fing everything damp and wet.
im an electrical engineer by trade, removed the control module to find the uln2003 blown up.
i replaced it and dried out the machine for a couple of days.
i finally got around to rebuilding it tonight, when i plug it in the 2 afroe mentioned lights just flash repeatedly and it wont do anything.
any ideas?
cheers scott
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
f1 and f17 share the same light
hi thanks for that, how are the lights numbered? 1 at the top and 4 at the bottom?
if so i have a communication error, what could cause that?
cheers
yes thats correct , it means the top pcb and bottom one are not talking to each other ,unplug the top pcb for 2 mins and try again. if it dont work then one or both pcbs are faulty .i dont know which component is at fault i would just plug in a new pcb at the top then the bottom one . exchange pcb from a company called emw in nottingham is your best bet and cheap they test the pcbs and tell you which one is faulty.
It is possible the new pcb is not programmed, if you change the main pcb at the bottom you may require a specialist tool to programme it
