Could do with help / any suggestions relating to the above.
Water is leaking from the bottom of the machine, seems to be internally and from the front end of the machine. Taking the thin strip off of the back of the bottom of the machine and shining a light in shows a lot of water droplets up the inner side of the front panel of the machine down at the bottom.
I have checked the big water outlet pipes at the back of the drum at the bottom, the ones held on by the big metal circlips and these are dry. The water inlet pipes leading into the powder dispensing drawer are also dry and the big pipe leading from the drawer into the drum is also dry.
I can't get the door seal off in order to remove the front facia around the door which should enable me to check the front of the drum inside the machine.
Any ideas how to get the door seal off, or indeed, whether this is necessary and someone has a good idea as to what the problem may be?
Many thanks.
Many thanks.
