hotpoint aquarius wma44 error codes ??
20 May 2011
Essex
help wanted,
i have a hotpoint aquarius extra wma44. it stops half way through its cycle, with 3 leds lit, (3,4,5) any ideas what might be the cause of this error code ??? i have cheacked the inlets and outlets all have no blockages..
dont really want to buy a new m/c
That fault can mean one of three things. Filter blocked , motor brushes worn , or heater faulty
Thanks, I've cleaned the filter out (it was blocked) but it still hasn't solved the problem.. I take a look for the price of a heater next
Cheers again
I haven't looked at the brushes, but I thought as the drum spins ok up to a point, my guess is that the motor is ok ???
Motor brushes wear gradually
First you will get poor spin on heavy loads, progressing to no spin on heavy and poor on medium. Eventually the motor will not operate at all but by then you also have a chance of the PCB/motor control being damaged and or the motor commutator.
New motor and or PCB then
