Hi I've got a hotpoint washer that is filling up with water too much. When the washer first fills the washer up it fills it for a bit, then you hear it stop for a few seconds, but then it continues to fill up until the water is halfway up the door and the water starts leaking out from the powder door (no idea if it eventually stops because obviously it gets turned off). The washer will pump water out it seems without a problem as when I set it to pump out, it does so. I've took the pipe off from under the drum (where the ball is, I'm guessing as a filter) and the thing that screws off at the bottom (still on the front) of the washer and both of those places are clear. I've also had the waste pipe in the sink to make sure that wasn't a problem but it doesn't seem to help.
Is there any common problems with washers (or this specific washer) or anything that I can try? I really haven't got the money to be getting someone out and I'm fairly confident at fixing things with instruction. Any help will be gratefully accepted, as my clothes are starting to smell! lol
Thanks, Craig
Thanks, Craig
