Hotpoint BFV620
16 Jan 2007
Oxford
Selected full wash cycle, turned machine on, first light(pre wash) came on as usual, nothing happened then after a while 2 nd light (Wash) came on and both lights started rapid flashing.
Phoned Hotpoint said blocked pump
Lugged machine in garage, dis assembled drain pump, all clear, rigged up heath Robinson wiring and checked pump - works fine, removed high pressure pump, did same as above , works fine, all rubber pipes checked and clear, checked solenoid for water in - works fine, all tubes and pipes clear. Pressure switch in base which activates when water in system checked, works fine, there is a sensor/switch running off a tube between the high pressure pump and lower spinning water blade but I dont know what this does, think its a water sensor but can short this out if necessary as it cuts into the high speed pump feed. Any Ideas cos my hands are sore with washing up and I want my garage back!
:cry:
