I have a hotpoint BHWD129 washing machine/dryer. The pump is not letting the water drain out.
Here's what i've tried already:
- Removing one end of the slump and checked for blockages, didnt seem to have any (did the end with ball in).
- Removed pump chamber and no coins etc. Turned machine on spin setting the impeller is spinning and hum as you'd expect normally, turns freely when you do it by hand.
- Checked ubend no blockages
- Its connected via a long waste lead plugged into another, my feeling is this may be blocked or was kinked, i've tried moving removing the kink and didnt help
- I also took the screws out and twisted and pushed it back into the machine to see if I could see anything but couldnt work out how to get the tight clips off either side holding it in.
I dont have any experiance at all really apart from watching them over the years but just checking the basics.
Any ideas what to try next my gut would would say it may be waste pipe drain hose related but without being able to get those clips off I cant take it off to examine, also how does it go back on?
Can anyone help?
Can anyone help?
