Hotpoint bhwm129
20 May 2013
Perthshire
Hi
I have a hotpoint bhwm129 integrated washer. Last night I started a load as normal and came back 10 min later to find all 4 lights flashing. Super wash, extra rinse, mini load and reduced creases. All flashing red. The machine hadnt done anything.
I know this probably relates to an error code. Any ideas? I have done all the usual things check flter and pump for blockage and ensured the drain hose is unblocked.
Best Regards
Drethewall
Need to know the status of the lights on the RIGHT.
Hi
The water heater light stays lit orange for a while and the door lock stays lit red then after bout 10min then just the door lock light remains lit redand the start/pause light flashes orange as well as the others to the left
Best regards
Drethewall
Water heater light ?? Only wash rinse spin drain door lock light. Top one wash rest as per list. Wash is 1 rinse 2 etc. numbers 1 to 6. Wot other light is solid. Apart from door lock.
Ok sorry. Its the wash light that stays lit for approx 10min then when the lights to the left all flash red its only the door lock light that remains solid
Best regards
Drethewall
You got error f01. Triac on pcb faulty. New pcb req.
Yes. U can two ways with this. Phone hotpoint all in parts and labour. £110.00. Or go to emw for a ex pcb at about 45.00.
