hotpoint blues
17 Mar 2010
Flintshire
hi problems with hotpoint fdw 60 dishwasher.
first it stopped working and i found the fault code to be a leak. on looking i found a mouse had got inside!! and made a sizable hole in the high pressure switch rubber hose (tee) as i couldn't see any other damage i purchased a new hose (which came with a switch fitted ) and I replaced that tonight but........ now a new fault code that I can't find!! lights 4&5 flashing (fast and prewash) anyone any ideas..... wondering if some water may have squirted somewhere!!!!
thanks
Hotpoint DWT 10, DWF 50 & DWM55 also FDW/SDW60 dishwashers
Led 1 Intensive
Led 2 Normal
Led 3 Eco
Led 4 Fast
Led 5 Prewash
Led 6 Delicate
3.....Overflow (water in base)-Leak from water line
4.....Solenoid valve fault -Inlet valve,connections
5.....Thermistor circuit-Thermistor c/w timer
6.....Timeout heating-NTC detached from casing
3+4.Timeout draining-Pump connections,blockage,module
4+5.Timeout filling-Tap off,Inlet valve,connections,timer,water turbine
3+5.Circulation pump not working- pump,connections,capacitor,module
3+5.Filters blocked-Mesh plate,filter or microfilter,pressure sensor
1+4.Software recognition error-Timer not programmed,wrong keypad
4+6.Heating circuit-heater,connections,module,relay
3+4.Hardware version (timer
