Hotpoint D/washer Leaks water into base approx every 5 uses
18 Apr 2007
Mid Glamorgan
I have a semi-integrated Hotpoint Dishwasher (model unknown as I cannot find an info plate anywhere) which appears to work/clean fine then intermittently activates the high level cut-off switch located in the base. I've run the appliance with the plastic covers removed & cannot seem to see where any water is coming from? :confused:
