Hotpoint DF23-Takes hours to complete cycle
6 Feb 2004
I have had a Hotpoint DF23 for 10+ years.
It is now taking about 5 hours to complete a wash cycle.
It's draining fine and appears to have water going in and is washing and drying without any problems.
If anything, it seems not to heat the water to such a high temperature as what it was before.
Any ideas?
You have a thermostat fault. Found near the heater at the bottom of the tub. And poss one on the door. You should have asked here first the other forum you asked on are a bit slow.
Rocks
Thanks for your help-thought I would try the dishwasher specific forum first-still awaiting a reply.
I take it, a change of thermostat isn't too challenging.....
Thanks again
Yep just pulls out and replace. There are two one in door one on base best to change both.
Rocks
Managed to find 2 thermostats on the base acting as supports to the heater.
Both are exactly the same type.
I take it both should be changed along with the rubber grommets.
Haven't found one in the door yet....
Yes both if them. Also shows one screwed under the tub and 2 fitted on the inner door. Remove outer door and they should be by the dispenser 2 round discs. You can test they by putting in a cup of hot water and checking resistance with a meter.
