Can anybody help with this fault, machine goes through what it always does when you turn it on by draining off water but thats all it does the drain pump just keeps going and going,the timer/clock goes right round past wash and dry to off but dishes not even touched.Could it be soleniod not letting in the water.If i put in about 4/5 pints off water and turn it on in the wash cycle the water sprays around until the pump has drained the water and thats it. Just a gurgling noise as pump tries to keep draining !
