- Joined
- 8 Oct 2011
- Messages
- 1
- Reaction score
- 0
- Country
Hello all
My FDW60 starts ok and fills with water through the side inlet valve enough to cover bottom of machine. Then should switch to main water fill through the spinning arms but no water comes in, just hums as though it's doing something. Seems to drain ok whenever I start a program and heater is obviously working as top spinning arm gets hot even though no water comes through, neither top or bottom arm are moving.
Tried different programs but get same problem, have checked for blocked filter or water sat in the bottom of machine but with no luck.
Can water inlet valve be faulty even though it brings in water initially, does the valve switch between initial hose and main inlet hose, could this be a problem does anyone know ?
Have checked loads of similar forum posts but not found one quite the same yet....
Thanks in advance
Thanks in advance
